04 chevy impala winshield wipers not working
my windshield wipers to a 04 chevy impala are currently not working.
checked the fuse over the weekend, it was severed/burnt out. replaced it with the 25amp fuse and now the water jets that spray out of the wipers work but the wipers themselves do not move at all.
can anyone tell me wat the problem may be at hand now. this is my first car given to me and im trying to get more into diy/maintenance oriented checks. all future help/info is much appreciated.
on other cars i can see it jst fine where the wiper motor is located. on my car im guessing its under the cowl/panel with the vents in it on the driver side. i will definitely get back to u with info once i take the area apart and see wats up. thx soo much for the help.
I looked on you tube, nothing for your model. You are probably correct underneath that panel. I found a Saturn, had to pull the dash panel. A Montana van, it was underneath the hood but also under a panel.
i fixed the motor by replacing it. it is under the cowl on the driver side, which is held in by the windshield wiper nuts (13mm), 1 screw tab and 3 plunger tabs if that is what they're known as. the motor assembly is held in by 3 t25 screws and 1 t27 screw. my wipers work for the most part. just need to fix the parking issue where they rest on the allotted space for them when not in use. back to working on the rx7 for now while my DD is drive-able through the rain season. thanks again for all your help mate.
unckybob
Express & G-Series Vans
February 13th, 2013 3:12 PM
AustinTahoe
January 18th, 2012 1:51 PM
KEO
Silverado & Fullsize Pick-ups
September 16th, 2010 3:20 PM
