Oxygen sensors - Chevrolet Forum - Chevy Enthusiasts Forums
Oxygen sensors
firepop5's Avatar
June 15th, 2009, 11:07 PM   #1
Oxygen sensors
On a 2001 Impala with 3.4L, how many oxygen sensors are there and where are they located?
Mike Sigmond's Avatar
ROTM Coordinator
Orange County, CA
June 16th, 2009, 1:32 AM   #2
You have 2.
One before the cat & one after the cat on your exaust pipes.
I cant find a picture but here is what the book says...
Removal & Installation
Upstream HO<SUB>2</SUB> S1
To Remove:
NOTE: If the engine temperature is lower than 120 F (48 C), the HO<SUB>2</SUB> S1 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust manifold.
  1. If necessary remove the fuel injector cover.
  2. Disconnect the HO<SUB>2</SUB> S1 sensor electrical connector.
  3. Using an oxygen sensor removal tool carefully remove the heated oxygen sensor.
To Install:
  1. Coat the threads of the oxygen sensor with anti-seize compound
  2. Install the HO<SUB>2 </SUB>S1 sensor. Tighten the HO<SUB>2</SUB> S1 sensor to 30 ft lb (41 Nm).
  3. Connect the HO<SUB>2</SUB> S1 sensor connector.
  4. If removed, install the fuel injector cover.
Downstream HO<SUB>2</SUB> S2
To Remove:
NOTE: If the engine temperature is lower than 120 F (48 C), the H0<SUB>2</SUB> S2 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust pipe.
  1. Raise and safely support the vehicle.
  2. Disconnect the HO<SUB>2</SUB> S2 electrical connector.
  3. Using an oxygen sensor tool carefully remove the H<SUB>2</SUB>0 S2.
To Install:
  1. Coat the threads of the HO<SUB>2</SUB> S2 with anti-seize compound.
  2. Using an oxygen sensor tool install the HO<SUB>2</SUB> S2.
  3. Tighten the sensor to 30 ft lb (41 Nm).
  4. Connect the HO<SUB>2</SUB> S2 sensor electrical connector.
  5. Lower the vehicle.
firepop5's Avatar
June 16th, 2009, 5:41 PM   #3
Thanks alot!
ROTM Coordinator
Orange County, CA
June 16th, 2009, 7:45 PM   #4
Posted By: firepop5 Thanks alot!
you bet.
milwaukee_01impala's Avatar
June 16th, 2009, 10:04 PM   #5
the upstream o2 sensor is on the rear exhaust manifold.
may i ask what you're inquiring about these for?
firepop5's Avatar
June 17th, 2009, 1:53 PM   #6
This is my brother's car and he asked me for some help. He had his computer scanned at a parts store and they told him his O2 sensors were bad. Wanted to have as much info as possible before I start troubleshooting since I'm not familiar with the car. If I decide to swap out the sensors, is AC Delco worth the extra money or are Bosch replacements OK?
ROTM Coordinator
Orange County, CA
June 17th, 2009, 2:06 PM   #7
What code(s) did it throw? They both may not be bad, it could even be something else.
firepop5's Avatar
June 20th, 2009, 1:36 PM   #8
I got to see my brothers car today. The "Service vehicle soon" message is showing on dashboard. I scanned the OBD2 connector and got no codes. I would suspect if his O2 sensors were bad, the "check engine" light would come on instead of the service vehicle soon light anyway. I don't know why the shop he visited said he needed Os sensors. I saw their diagnostic report, and there are no codes listed, just a quote to change the O2 sensors.
According to his owners manual, if the service vehicle soon message appears, you must visit the dealer, or there is a problem with a trunk safety system. I'm pretty sure the car doesn't have this safety system on it.
After a little research I suspect the Body Control Module (BCM) is turning on the light. Does this BCM have a diagnostic connection and would an Auto Zone or similar place be able to diagnose or pull codes?
July 5th, 2009, 8:20 AM   #9
no, autozone or any other parts store wont be able to read BCM codes. you'll most likely have to got to a dealer to get those codes as those codes can only br read with a tech II scanner. the only place i've seen with a tech II is a dealer. you dont have to take it to a chevy dealer, any GM dealer will have a tech II scanner.
firepop5's Avatar
July 6th, 2009, 1:43 PM   #10
Ared the BCM codes also accessed from the OBD2 terminal under the dash?
Tags
Sponsors
  • Ask a Question
    Get answers from community experts
What's your question?
Send
