2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2002 Impala AC Problems
Old April 25th, 2011, 10:06 AM
jbizub5192's Avatar
Default 2002 Impala AC Problems
Hi everyone, Last year I had to recharge the ac system because the system was low. I had to charge it again now because it low, Its only a small leak so I could put up with recharging it. The problem I have now is after I pulled a vacume on the system and then recharged it I still have no ac! But I did notice that the small ac line going into the firewall ices right up in about 30 seconds as soon as you turn the ac on. What could be causing the line to ice up which im pretty sure is the reason why I have no cold air. The compressor kicks right on like its supposed to but I get no cold air lol.
Thanks for the help!
Old April 26th, 2011, 10:03 PM
jbizub5192's Avatar
Any Ideas lol? Thanks
Old May 12th, 2011, 10:02 PM
jbizub5192's Avatar
Does anyone have a idea what could be causing this?
Old May 16th, 2011, 11:00 PM
jbizub5192's Avatar
I cant believe know one was any ideas?
Old May 17th, 2011, 4:03 PM
Gwampa's Avatar
Patience is a virtue......someone will answer, just gotta give 'em time.
Old May 19th, 2011, 8:48 PM
jbizub5192's Avatar
Sorry im just used to all of the other forums i belong two and they usually respond within a hour
Old May 31st, 2011, 11:53 PM
jbizub5192's Avatar
Still no ideas?
Old June 1st, 2011, 8:20 AM
Did you replace the accumulator? its possible the accumulator has become clogged and not allowing the freon to flow properly...
Old June 1st, 2011, 8:41 PM
klutz1's Avatar
Freezing is caused by a rapid decline of high to low pressure pressure. The exact way it cools. Possible the leak has grown. Do you have gauges?
Old June 2nd, 2011, 9:27 AM
jbizub5192's Avatar
Thanks for the response! I did not replace the accumulator and didn't check that. Where is that located? By the firewall? I do have a set of gauges and If I remember correctly it was around 150 on the high side. I forgot the low pressure. What should the pressure be? Thanks again!
brentandbecky
July 21st, 2016 3:41 PM
pen63
July 8th, 2011 12:54 PM
bwgood
April 27th, 2007 12:28 PM
Quick Reply: 2002 Impala AC Problems
