Please help 00 impala nightmare
Recently bought a 2000 Chevy impala. First night driving noticed I had no dash lights and my heat and ac gauges were not lit up either. Checked all the fuses they were all good. Pulled the dash apart everything seams to be hooked up. So taped a flashlight to dash. I can deal with that. I made the mistake of letting someone try to swap out my factory deck for another one long story short they did a horrible job. Went to start my car and nothing happened besides powering on. Car made no attempt to star. Removed the deck and now have just a hole in dash but car starts again. Next day was told my taillights were not working. Took it to shop to see if they could help because it was not a fuse or bulb. They said replace headlight switch. Replaced headlight switch and I now have no blinkers or brake lights either. My reverse lights still work though. Did find some janky wiring and rewiring that is clearly not factory and was wrapped in duct tape instead of electrical tape. Can somone please tell me how to make my rear light work. Have had multiple people look at it but nobody has been able to pin point the problem. Was thinking maybe the ground for my rear light? Someone else had suggested a blinker switch but seeing as I replaced headlight switch and it got worse I don't want to waste my time and money. I am a widowed mother and do not have a lot of cash.
The fuse panel on the right side of the instrument panel has a park light relay and fuse. Re-check the ' REAR PARK LP' fuse. To test the relay, try swapping the 'PARK LP' relay with the 'BACKUP LP' relay.
With the lights ON, try pulling the 'PARK LP" relay, you should be able to hear the relay click ON/OFF while pulling/plugging-in the relay. If you don't hear it clicking you may have issues with the wiring to the light switch.
The HAZARD warning light switch is a common problem for malfunctioning turn signals. Do the lights work with the HAZARD flasher ON? Try cycling the switch ON/OFF a few times.
