Transmission Whine
Transmission Whine
2007 Impala with 69000 miles. Low level transmission whine when accelerating after descending steep hill. Louder when descent was in 3rd or 2nd. NO whine during descent only after complete stop and accelerating from stop. Whines also after coming off expressway ramp to dead stop and accelerating from stop. Fluid level good and clean.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Dean0849,
A transmission whine noise can be an indicator that the transmission components (bearings or gears) are not rotating correctly. It is possible they are worn out or damaged. This is just a suggestion, not a diagnosis.
I suggest you take the vehicle in for an inspection. A certified technician will be able to offer an accurate diagnosis after a physical inspection.
This is an issue that you will want to take care of sooner than later, as to avoid more costly repair in the future.
I hope this information is helpful.
If have you have additional questions, please feel free to contact me.
Louis
GM Customer Service
Louis
GM Customer Service
reelcharacter
March 30th, 2022 10:35 AM
randyehughes
September 29th, 2019 9:58 PM
randyehughes
Silverado & Fullsize Pick-ups
June 7th, 2006 5:56 PM
2007, 2010, accelerating, chevy, exceleration, gm, impala, noise, sound, stopping, tranmissiom, trans, transmission, whine, whining, whistle, wining
