wont start need help please
hi i have an 87 k-5 blazer with a 305 tbi and im haveine trouble with it was running great we parked it came out few hours later and it wont start it cranks over and we can hear the fue pump when we get under the truck by the tank we have no fuel fromthe injectors or spark from coil or from the plugs
RE: wont start need help please
My 87 has done the exact same thing. I have been trying everything. I had just installed a brand new accel ignition system, I mean I replaced everything with all accel. Run great for about a week, went out one afternoon to run up to the store and that was it. I wrote the accel tech's about it and they said that the only thing that would stop the fuel and the ignition system at the same time would be the ECM (computer). I have been trying to get some second opinions.
I checked all my grounds today to make sure all was tight and checked the trouble codes and the computer showed no trouble codes. Replaced the fuel pump relay. No luck yet.
Got it!! Found a link in the forum to the burb section that led me to the ignition module. I took out the new accel Ignition module and had it tested and it was fried. Installed a new ac delco module and it fired up and run beautiful. So much for Accel. In the link it says that the module not only controls the fire to the plugs it also sends a signal to the computer to let it know when to inject the fuel. Good luck on yours Db.
Igor_Kiforishin
December 10th, 2014 3:34 PM
willys473
Silverado & Fullsize Pick-ups
September 25th, 2009 5:34 PM
