k5 blazer will not start after it gets warm ?
I have a 1991 5.7 k5 blazer having some problems if somebody might can help. It will start then run for a while then it wants to cut off like its losing power after it shuts off it will not start back up until it cools down. I have replaced the dist,rotor,spark plugs,wires,coil pack and fuel filter seems to be getting gas and spark but will not start. And i have checked the fuses the battery is a little week sometimes have to jump it off.
Are you refering to the bendix, or solenoid? If the starter is hot, and the contact disk in the solenoid is "burnt", you will have issue with what appears a low battery on crank.
Well, not being very mechanically inclined, all I can remember is that the mechanic showed me a spring he had replaced and said it was from the starter. The mechanic was my wife's uncle, a good guy, with no reason to tell us something that wasn't true. He just wanted to help, had experience with Chevys and knew immediately when told about the symtoms.
Been a few years (about 1980) and that particular brain cell is only working part time. But, if I recall, the spring was maybe 1- 2 inches long by about 1/2 inch I.D.
Why does my 2000 Chevy Tracker with 20 engine die after it gets hot but restarts OK after cooling fo
vixendrumr
November 8th, 2010 2:42 PM
