03 malibu anti theft
You will not be able to remove the anti-theft system from the vehicle. You need to have the code stored cleared or solve a possible issue that is causing the system to activate. Such as a possible faulty door latch assembly.
10-minute trick
You will see several other posts relating to this problem as well. Use the manufacturer's suggested 10-minute trick, where you put the key in, turn only to the on position for ten minutes (don't try to start yet), then turn off and turn back on to start the car. It is a simple albeit infuriating feature buried in your owners manual.
jhl1188
September 8th, 2007 11:26 AM
