03 Malibu horn/wiring questions
Hey all so my horn stopped working checked fuses relays all good when I press panic or lock on key fob the horn works. I'm thinking it's the switch.
I want to by pass the steering wheel pad and put in a momentary contact switch I've looked online an all I found was horn trigger (-) is black where and what color is the positive? And what's a good way to access it?
A second question maybe related or unrelated I believe my MAF is acting up. The engine sometimes would miss/ hesitate idle drop lights dim or stall when in drive with brake applied but in park would be fine. I've cleaned the maf but no result. Could this be a ground issue maybe connected with horn? I'm not sure how to test the maf
Thanks in advance.
Thanks in advance.
1978 Chevrolet C10 half ton horn contact/ horn wiringI have a 1978 Chevrolet C10 that it's horn does
isaac_22
Silverado & Fullsize Pick-ups
December 26th, 2007 9:23 PM
zulu
March 28th, 2007 4:58 AM
