Chevrolet Malibu
2004 chevrolet malibu maxx tail light issue
Old March 7th, 2015, 10:20 AM
ex0r's Avatar
Default 2004 chevrolet malibu maxx tail light issue
My tail lights stopped working, and I assumed it was the bulbs. I took the lamps apart to replace the bulbs and noticed they were fine. I then checked the rear fuse box, and noticed that the brown wire that connects to the tail lamps was pulled out from the back of the fuse panel. The crimp connection is still on it, it just looks like it pushed out of the hole on the back side of the fuse panel. I was trying to locate the correct hole for it to go into (I can see where the two green wires for the tail lamps go in), but I cant seem to find the right hole to push it back through. I noticed, on the back side of the fuse panel, there is a red 'connector' that those wires go into. Is it possible to remove this from the back of the fuse panel, so that I can fix the wire? I tried pulling it out by the four red tabs sticking out of the four corners, but was unable to remove it.
If this cant be removed, how can this be fixed? It doesnt appear the crimp connector broke, it just pulled out of the hole it goes into to make contact with the fuse.
wceager
October 13th, 2015 2:32 AM
TASpinney9110
October 8th, 2012 8:02 PM
Mr.K
December 18th, 2008 6:00 AM
bennettcl
February 3rd, 2008 10:17 PM
bryan0422
July 13th, 2007 8:25 PM
Quick Reply: 2004 chevrolet malibu maxx tail light issue
