2005 chevy malibu heat and ac problem
Ok 2005 chevy malibu. Fan hits on all speeds rear defrost works. temp control does nothing no heat no ac. Blower blows from dash vents only no defrost no foot no blend on vents no nothing. Compressor does not click on for defrost because it will not switch to defrost mode when I turn the vent selection anywhere... I press the button for the ac nothing the light does not come on and the compressor does not come on... It has freon. Temp gauge holds steady at midway point. I checked all relays and fuses I also replaced the actual climate control unit same thing blower blows on each setting nothing else works cannot change temperature cannot chage from panel vent to widow defrost or foot or blend. AC button no light compressor does not turn on and the button to choose recycled to fresh air does not work either... HELP...
was gonna put my two cents in but thats a hard one. I would go over all electrical wires and connector that have to do with the climate control unit
