Chevrolet Malibu
2006 Malibu wont start without pressing gas pedal
Old June 30th, 2014, 4:23 PM
dmkilgo's Avatar
Default 2006 Malibu wont start without pressing gas pedal
I have an 06 Malibu with a 3.5 v6. When you try to crank it the starter will turn but it won't hit. It does this randomly. If it ever happens, all I have to do is press the gas pedal and it will fire right up. I wouldn't mind except for the issue this causes with the remote start. If you attempt to start the engine with the remote start feature and it doesn't start, the starter just continues turning over until you go unlock the door, get in, insert the key, and turn it on manually. Does anyone have any idea why it would do this? I've been told by a friend who used to work in a Chevy service department that it was a common problem, but that he didn't know of a fix. Didn't have time for details when we discussed it, but I believe he mentioned something about a problem in the computer that controls the fuel pump. Any ideas?
Old October 27th, 2014, 12:06 AM
ghostlegz's Avatar
any trouble codes maybe tps bad
Old January 11th, 2015, 1:00 AM
malibu mann 0406's Avatar
MY 04' does this sometimes, it has the 3.5 v6 but i know of no fix for this, maybe it needs a throttle position sensor like ghostlegz said
Old January 23rd, 2015, 12:26 PM
srp204's Avatar
Try the easiest and cheapest first, clean the throttle body with some rubbing alcohol and a toothbrush. You do get a buildup and it can cause annoying little problems, it takes a few minutes and see if it cures the problem.
krash
Express & G-Series Vans
April 4th, 2016 6:49 PM
kewman22
Silverado & Fullsize Pick-ups
May 9th, 2012 12:54 PM
caddieb
May 15th, 2011 5:32 PM
tlspirit
October 17th, 2010 9:17 AM
chrisificti0n
June 24th, 2010 7:29 PM
Quick Reply: 2006 Malibu wont start without pressing gas pedal
