Battery dies overnight 06
i have an 06 maxx SS, that kills the battery overnight. Its a new battery, i checked the sitting parasitic amps, its in the 300 miliamps range. if i remove the fuses to find the cause it looks like the BCM is pulling the current. Where is the BCM located? I have nothing else in the car ie:aftermarket anything. Its done this before and went away for quite a while now its back. So where is it located. other than this , ive only had to replace the TPS on the intake.
Bob
Bob
Bob
Bob
its 250ma over spec.! manual says 20 to 50 mili-amps dead idle. after 10 minutes or less. its done this before. and went away. if i pull the fuse for the BCM it drops to almost zero.
so does anybody know where its located?
TRock
February 19th, 2006 7:44 PM
