Can a code that says Engine Misfire cylinder 3 ever be real serious??
Can a code that says Engine Misfire cylinder 3 ever be real serious?? Im looking at a car that I can get at a good price. The current owner is moving and needs to sell. He also said this code came out of the blue/ With all the problems the 3.1 engine has had can this error code ever lead to any REAL SERIOUS AND EXPENSIVE SOLUTIONS?? OK I know it can at times but what is the likly hood that this issue can be corrected for less than a couple of hundred dollars?
I honestly dont want to deal with changing the head gaskets etc. Please Im really under the gun and need to make a quick decision.
I got lucky on my other daughters malibu basically the same thing except this car was overheating however I discovered that the head gasket was ok so I purchased the 03 malibu for $1100 and everything workedout fine.
Im hoping this can occurr one more time!
assume the worst and make your offer accordingly. Without any diagnostic testing; its all a guesswork.
Do a compression test to rule out anything mechanical. While the #3 plugs out inspect the plug and take a look into the cylinder for coolant etc.
RacerX
March 17th, 2012 6:10 AM
syuchimiuk
Express & G-Series Vans
March 20th, 2011 10:54 AM
larry_chip
April 24th, 2007 11:46 AM
