01 Malibu wont start, theft light always on
I would like some help with this. My 01 malibu is sitting in the driveway for the past 3 days... After reading many treads i went and change the lock cylinder with no result. My old cylinder was damaged (a lot of usage 430000 kms) so i still needed to change it and i went to the whole put key on ACC and wait 10 min for the computer to recongnise the new cylinder but it still wont start, it does not even crank, any ideas??
I will go and try that right now. The light stays on as soon as i turn the key to ACC. I was able to drive for a while with the light on but then one evening, it just did not crank anymore. Keep you posted.
Thank you
Disconnected the batery for over an hour, still wont crank and theft light still on as soon has i turn the key and stays lit.
Any other ideas??
Getting frustrated...
Thank you
Any other ideas??
Welcome to the forum. See my post #4 in thread https://chevroletforum.com/forum/mal...es-more-42282/ on the THEFT SYSTEM indicator. A solid THEFT SYSTEM indicator usually means the BCM declared a Hall effect sensor tamper condition. You did reconnect the three-wire connector (WHT, YEL, and BLK wires)? Also with the Passlock system, the ignition switch and lock cylinder (rekeyed to the original key) are usually replaced together. It sounds like either a fuse blew or the ignition switch is busted in addition to the Hall effect sensor wiring problem.
i did reconnect the 3 wires. i got the ingnition switch complete with lock cylinder at a scrap yard. The guys there started the car from wicht it came from in front of me so i know the switch works. you guys mentionned the theft fuse or a fuse, where should i start looking?
I got the car batery charging right now cause i got my hands on a OBD2 and attempted to erase the codes but the car batery went dead before i could perform the whole test...
You originally stated that you "went and change the lock cylinder" and you now seem to be implying that you had changed the ignition switch as well and "the car batery went dead" in the meantime. It sounds like you have electrical faults (I had mentioned "a fuse" in a generic sense) on top of the Passlock problem. Mind, the latter will not prevent the engine cranking. Anyway, I really don't have a suggestion for you on how to proceed at this point.
have you figured it out
I just drove my car parked it and it won't start the alarm keeps going off. I need help. I did the lock and unlock. Take the cable off for 30mins and all. Nothing
I have not posted in ahwile, the only reason for this is to try to help out with the security issue. I had the same issue a few months ago (again), i had to replace the worn out ignition switch in my 96 lumina. That cured it. I am sure Allen in NE will correct me.
Disastro2000
Astro
February 17th, 2024 7:11 AM
damone
Silverado & Fullsize Pick-ups
May 8th, 2021 12:36 PM
