Cruise Control Issues
New User
Awaiting E-mail Confirmation
Evening
I have a 2008 Chevy Malibu and I've noticed that the cruise control seems to work when it feels like it. Anybody experience the same?
Thanks
http://www.yourwhip.com
Thanks
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Rashad Woods,
It may be an issue with the body control module (BCM). You may want to take the vehicle in to be inspected by a certified technician for a more accurate diagnosis.
Louis
GM Customer Service
Louis
GM Customer Service
New User
Any reason this would just start happening recently? It worked fine for the last 2.5 years
You belong http://www.yourwhip.com
could be a couple things...wore out/stickings witches or BCM problems...hard to give you a good direction with it being intermittent best bet is taking it to a shop
The brake lights are on without the foot on the brake pedal, maybe? Do a web search for TSB #08-05-22-009 (currently up to revision #08-05-22-009C). Some shops will start with replacing the brake pedal position sensor and generally flop around which is patently the wrong way to go.
pcwilcox
October 21st, 2013 11:00 AM
CoryWinburn
Silverado & Fullsize Pick-ups
October 9th, 2013 6:29 PM
liljoe66
August 5th, 2011 12:44 PM
