Chevrolet Malibu
Front Shock Absorber Noise Solved
Old July 17th, 2013, 1:32 PM
Communer's Avatar
Default Front Shock Absorber Noise Solved
A rattling noise began that appeared to come from the driver side front of my 2002 Malibu Basic. It sounded as though it came from under the dashboard, so I removed the bottom panel and found a connector module had broken free of its velcro support. I re-attached it, but the noise continued.
I checked for loose components in the engine compartment but found none. I examined the driver-side shock absorber but saw nothing wrong with it.
As the noise gradually became louder, I discovered its source was the upper strut mount in the engine compartment. The two top pieces of plastic were grinding together.
I sprayed them with silicone, and the noise abated for a couple of miles and then returned, so I sprayed them with WD-40 and injected grease, and the noise disappeared.
Old August 11th, 2013, 12:01 PM
New User
Awaiting E-mail Confirmation
bennybear1's Avatar
I just put strut kits on front of my 2006 malibu its making a mount noise on both new struts any adjustment I can make that will help
Old August 11th, 2013, 12:10 PM
SWHouston's Avatar
WOW finally, something that WD-40 is actually good for !
But I bet it was the Grease that actually did it !
Michael J.
Silverado & Fullsize Pick-ups
January 14th, 2014 4:20 PM
paintinx
October 3rd, 2013 3:07 PM
cowpoe2
June 25th, 2011 5:05 PM
99er
July 23rd, 2010 12:54 AM
fullmontecarlo
September 17th, 2008 11:23 AM
Quick Reply: Front Shock Absorber Noise Solved
