2008 Malibu will not start or crank
I've read all through these forums and have not found the answer to this problem. Here is the troubleshooting I have already done.
-Replaced battery - I knew it needed to be replaced because of corrosion (blue stuff) on the negative terminal and verified that it had 12.4 - 12.6 volts. Although now it reads 11.6.
-Traced to the Starter relay and completed the circuit. The engine DID crank! However will not start.
-Tried the anti-theft reset (even though the anti-theft light was not on)
-Tried starting in Neutral/Park, jiggling the shifter, 20 or so times
I'm not sure how to trace it down further.
https://chevroletforum.com/forum/mal...p-66004/page2/
Official GM Rep
Hi schommy98,
I'm sorry to hear of the difficulties that you are experiencing with your Malibu. I would like to look further into your concern and contact your dealership on your behalf for further assistance. Please feel free to send us a private message with your full contact information, VIN, current mileage, and dealership name if any extra help is needed. I look forward to hearing from you!
Kristen A.
Chevrolet Customer Care
Kristen A.
Official GM Rep
Hi krick211,
I'm sorry to hear that you are also experiencing this concern with your Malibu. I will be sending you a private message in order to further discuss your concern. Hoping to hear from you soon!
Kristen A.
Kristen A.
I should have updated this a long time ago. I had the vehicle towed to the dealer and the problem ended up being the ECM (Engine Control Module). It sits right in front of the battery.
summit800
Silverado & Fullsize Pick-ups
July 22nd, 2013 7:57 PM
