Help!
Help!
Can someone please help me figure out what could be going wrong with my malibu?? it was running fine last night, this morning i woke up and went to start it, It cranked over once then stopped trying to crank over. Now it wont crank at all. Ive checked the battery, its good and as far as the fuses i think there all good.. what could this be??? on my dash in the message thing it tells me to service esc, service traction, and power steering??
No unfortunatly i cannot affort to take it to a mechanic, and we switched batteries and put a new one in and still nothing, idk what else it could be causing it to do this
Where is the crankshaft position sensor located? and i havent checked the starter yet. But i guess this is a common problem with some chevys, i was reading online and several ppl have had this same problem but different things causing it.
My boyfriend jumped the starter solenoid with jumper cables and the starter turns over but still won't start it (with the key forward). Also, when the key was turned on (before starting) the check engine light would come on for a second with the rest of the lights and now it's not coming on at all.
Do you have fuel?
