Severe Misfire
Severe Misfire
I have an 06 malibu ss, 3.9L, i just recently changed the spark plugs 1,3, and 5. The numbers 2,4, and 6 are changed as well, but when the engine runs at idle for a minute or so, the traction control light comes on and the check engine light flashes. Anybody know what my issue is, i have a code that the fuel sending unit has high voltage output, was running fine before I changed the plug, theres a knock every few seconds and then runs smooth and knocks a few times and repeats that pattern.
I did not remove the plenum, but the air intake, i disconnected battery, so I could unplug the rear O2 sensore and the electronic distributor sensor and the,intake sensor as well as the connections to the alternator to pull the,harness out of the way, and I took off by accident the plastic vacuum line that connects to the intake into the cylinder head
