Chevrolet Malibu
Stupid question about my 2005 radio display
Old April 12th, 2016, 11:02 PM
Uranium-235's Avatar
Default Stupid question about my 2005 radio display
I replaced my battery on my 2005 2.2l maxx
I've done this before, but this time, the radio has done something it's never done before. The time display is blank. I can hit info and cycle through the milage, avg speed and whatnot, but as soon as it hits the display for the time it goes blank. I set the time and right after, it goes immediately blank. I can hit the info button and it comes up for a few seconds then goes blank. I've searched the manual and google ant turned up nothing on this problem. It's probably not a problem, just a button I have to push
Its the minimum radio, no tape, xm, aux, just single cd and radio
Old April 15th, 2016, 3:32 PM
inewhall760's Avatar
this happened to me, but the terminals were loose and it glitched out. What i did was take both terminals off, and turn the key to on to let loose any remaining power. then i screwed the terminals back in.
Old April 18th, 2016, 12:49 AM
I wasn't as careful.
At the time I forgot exactly what you said, so I turned the key one to start and disconnected/reconnected ground.
Went in and the radio display said engine power decreased and engine disabled.
Then I turned it to acc instead, reset the battery and it worked fine, clock displayed good, might have found a prank to play on my mothers malibu if the "engine disabled" works on a 2011 malibu
Old April 18th, 2016, 11:58 AM
Haha there you go. I pulled the relay on my dad's fuel pump once. Glad it worked out.
Old April 27th, 2016, 11:59 AM
Thank you for the info.
