Platform: A-, G-, & W-body
3.1L MAF min frequency
Old September 6th, 2016, 3:35 PM
kevinkpk's Avatar
Default 3.1L MAF min frequency
I am having (possibly vacuum) issues with my lumina dying at times with PO101. I replaced the valve cover vacuum line, still quits intermittenly. I need to know what the low end (idle) frequency range is. I did watch a youtube for an 8.3 L, might be the same min max low end acceptible range.
Old September 20th, 2016, 12:29 PM
kevinkpk's Avatar
Well, apparently 2K hz is the minimum at idle.
Old September 25th, 2016, 9:36 AM
kevinkpk's Avatar
Still have an issue. Car dies with CEL, po101. I have to erase the code for it to start, and run (intermittent). This started a month ago with what I thought at the time a vacuum leak. I have replaced the maf, unplug it running stays running, what I don't get is the po101 causing the engine to die, or is this something else?
