dead battery
dead battery
my lumina will drain the battery overnight any ideas I ran an amp gauge on the positive wire to starter shows1.5 amp drain seems lik a lot , bad ignition switch? have replaced alternator starter battery used to take 2-3 days not driving to drain now 1 day?
i work in a shop with 30 mechanics and the guys that i trust tell me its a possibility that it can be the multifuntional switch that controls the signals
fyi: i had the same problem and after much probing it turns out it was the ABS. so i disconnected the unit and its bfine now
Can be the same thing with glove compartment lite , under hood lite , trunk lite ..........
Remove the bulbs , one at a time , to make it easier to figure out what is working & what is not .
God bless
Wyr
