Welcome to Chevrolet Forum - Chevy Enthusiasts Forums
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Monte Carlo & LuminaSince the 1970s, the Monte Carlo has been an icon of American stock car racing. A 4-door version, the Lumina, was produced in the late 90's. Platform: A-, G-, & W-body
Hi. I was told by 3 different people that I needed to have my Low Coolant sensor replaced. The light was coming on intermittently at first, then flickering, then stayed on. All levels of coolant were fine.
I had the sensor replaced and now the light just stays on constantly. Is it something with the computer? I don't know. I was also suggested to unhook the battery for a few seconds and hook it back, that that should reset things.
Could that help or what else could it be?? Help! Thanks
Register today for free or log-in if already registered to remove this ad!
Can you pull the sensor out and see if its clogged or dirty, maybe a simple cleaning on the sensor might do the trick. Just trying to think of things to try without spending $$.
I am sure some other members will chime in and have more info on your problem. At least the battery disconnect does not cost any $$ even if it does not correct the problem.
