Dakota led lighting problems
Old July 17th, 2015, 8:15 PM
Bryanhorvath's Avatar
Default Dakota led lighting problems
I bought new led sequential lights for my 73 nova. I changed every light to led and the flashers (4 ways and turn). Everything works fine with key on but not so much when the engine is running. They flash fast and blink when they shouldn't be. Can figure it out? Don't know if it's the actual led tail lights or something else. Any help would be great thanks
Old July 31st, 2015, 5:30 PM
johnbradshow's Avatar
You need to put resistors or replace your turn signals flasher module when you changed to LED bulbs to fix the hyper flash issue, I would contact Xtralights online to see if they have the resistors/flasher unit for your car.
Old December 31st, 2015, 10:17 PM
I also have a 73 nova and put sequential LEDs. Flashers also, your problem in electronic noise. Check your alternator. I did this and everything was fine. Then to recall I also installed a msd hei billet distributor at the same time. Called msd and they admitted that it was the abundance of power for the coil and if my wires were anywhere by the distributor that would be a problem. Hope this helps you out
cdougherty91
Silverado & Fullsize Pick-ups
October 3rd, 2015 10:35 AM
Wills.WindowsAndWheels
Express & G-Series Vans
November 5th, 2014 8:05 AM
carpakacarp
Audio/Visual Electronics
February 20th, 2012 3:38 PM
IncisionInd
September 12th, 2009 11:13 PM
Quick Reply: Dakota led lighting problems
