93' chevy c1500 4,3L rotor incorrect position
Old March 28th, 2017, 7:15 PM
Javier Gutierrez's Avatar
Default 93' chevy c1500 4,3L rotor incorrect position
Hi there!
I was adjusting the valves for this truck due to a noice, but notice the rotor is 30 degree ahead of #1 spark plug wire terminal if damper line is align with timing mark (0) in front the engine . Can anyone advise on any document to check the whole ignition system and valve adjustment ? I follow a procedure of removing the spark plug for piston #1 to check the TDC, but the noise is higher now. Any advise will be appreciated . Thanks
