93 k1500 350TBI codes and hesitation help?
Old September 12th, 2014, 8:19 AM
gjoakum221's Avatar
Default 93 k1500 350TBI codes and hesitation help?
My 93 extended cab k1500 has a bad hesitation when first pulling out from a stop and if I step on it. Here what I did. Changed fuel filter, did oil change & filter, plugs wires , cap & rotor. I pulled the codes and was getting 6 of them. 1 was the throttle voltage was low so I replaced it. 2. Was fuel relay. So I replaced that. Getting code 72 saying output speed sensor, another code saying transmission temperature is high, trans temp hot. And something saying that something about A &B shift module. So after replacing the fuel relay and tps my service engine light went off and those codes are now gone. But I'm puzzled by the 4 tranny codes that I am getting . The little info I found about them says it could just be a broken wire. But I don't know where to start.. Any help,would be. Appreciated
Sfrey
March 22nd, 2015 10:07 PM
sydbarret1946
Silverado & Fullsize Pick-ups
August 26th, 2014 3:51 PM
TheDash
December 24th, 2010 8:21 PM
92Stepside
14
June 7th, 2009 11:07 PM
onsite
May 8th, 2008 11:31 AM
Quick Reply: 93 k1500 350TBI codes and hesitation help?
