blazer wont start
blazer wont start
i have a 93 s10 blazer 4.3 vortec im pretty sure i have the timing right it gets good spark is getting gas but wont start it wont even backfire so if anyone can give me any help i would appreciate it
RE: blazer wont start
ORIGINAL: sickvortech1
Try spraying stater fluid in the throttlebody and see if it cranks.
Yes be very careful if you have to spray the throttle body.
If thats not the problem...
You think you have the timing right, you have a spark, and you have fuel. Next thing to check is compression. If you find that you have compression, you will want to double check your timing. Otherwise, make sure you intake is free and clear and make sure you are keeping the exhaust backpressure.
sleepingciv
July 25th, 2020 1:03 PM
pantera8250
March 11th, 2010 1:04 PM
