1993 S-10 2.5L TBI really hates <15°F
When I turn the key to on, I can hear the fuel pump pressurizing the lines. Usually, it is on for maybe 3 seconds and stops. I turn the key to start, and the engine turns over just fine, but does not start if the outside temperature is less than 15°F.
Once I let go of the key, I can hear the fuel pump trying to repressurize the line, and it will run for up to 30 seconds (WAY longer than normal) until it either gets the line to a minimum pressure, or just gives up.
This has happened every winter for the past 3 years. The first winter, taking a hair dryer to the fuel filter (an idea on a hunch) seems to be enough to thaw something out, because then the line would pressurize normally and I could start without an issue.
The second winter, I changed out the fuel filter, but I still had the problem. I didn't try out the hair dryer after that, however.
This year, I'm fed up with it. I changed my fuel filter the second year because I assumed it was full of water or something, and it would freeze the line up when it got cold enough.
The interesting thing is that if I can get it started, then I don't have a problem at all after that. It runs with normal engine power and has no acceleration lag that you'd expect with a mostly clogged fuel line.
I'm at a loss. Any suggestions?
HowStuffWorks "Why is it so hard to start a car in the winter?"
What is happening sounds normal. Try adding some HEET to your gas tank and see if it will help your problem.
Nothing in that link discusses a fuel line not pressurizing. The fuel hasn't even reached the point in the delivery system where it is supposed to vaporize.
Heet does help sometimes, but not always.
Dylly
Silverado & Fullsize Pick-ups
August 6th, 2011 7:10 PM
branch
June 22nd, 2011 3:11 PM
Jeepdude123
December 21st, 2008 6:57 PM
