2001 S-10 ran hot now wont start help
Hey all, I have a 2001 chevy s-10 2.2l eng, The truck ran hot today, shut it down and towed to house, Found radiator clogged , Now the problem, I wanted to make sure the eng was ok so I tried to start the truck after it had cooled down for a few hours, Put Water in radiator tried to start, but the truck want start, I removed plug 1 and 3 TO check the coil packs and I get fire at the plugs
I reset the ecm, still will not start
Hey all I noticed lots of views but no replies, I changed the wires today and no start still, Is there anyone that can tell me a way to check and see if the timing is jumped I hate to go that way and it not be the problem, Is there a sensor that I can check that would cause the eng not to start even though I have fire at the plugs Thanks
ok so I know your post is old but I figured I would reply. Why check all ignition aspects when the initial cause of shut down was a clogged radiator? First you did not use straight water, did you? Also, did you check the thermostat to make sure it isn"t stuck open or closed? And check that water pump.
caddieb
May 15th, 2011 5:32 PM
