S-10 & Blazer 1982-2005
Will a 98 s10 rear end fit a 94 s10?
Old August 24th, 2015, 8:21 PM
Fliver's Avatar
Default Will a 98 s10 rear end fit a 94 s10?
I have a 94 s10 pickup 5 speed whose rear end went out. I have a friend who has a 98 s10 pickup 5 speed he wants to part out. Will his rear end fit my truck?
Old August 25th, 2015, 4:35 AM
Richardx2's Avatar
It should fit but it would be best to measure the length of the axle from backing plate to backing plate and also measure the distance between the yoke on the differential to the mounting plates for the springs.
In addition make sure the U-Joints are the same.
Old September 6th, 2015, 11:08 PM
toocute350's Avatar
It should but do your home work first.
Old January 28th, 2016, 9:12 PM
Fliver's Avatar
Thanks for the replies. You were correct. It does fit, however, the emergency brake cables do not. They are different.
hardbalance
April 30th, 2015 10:57 PM
WASP
February 24th, 2013 6:21 PM
bigcountryy
January 12th, 2013 12:55 PM
TASpinney9110
March 15th, 2011 5:54 PM
hydrodriver
Astro
December 11th, 2010 8:52 AM
Quick Reply: Will a 98 s10 rear end fit a 94 s10?
