2001 S10 2.2L Intermittent no crank/start
I've been having a a intermittent no crank/start for a few months now and its getting worse. It always starts first try in the morning when its cold, then i have trouble with it the rest of the day. So far I've changed the ignition switch and removed starter to test it and it tested good. I've been reading up on starter heat soak and thinking that could be the problem. What do you guys think? any tips or advice would be greatly appreciated.
Thanks!
Thanks!
