S-10 & Blazer 1982-2005
2002 blazer 4x4 wont go into 4hi
Old December 5th, 2006, 10:43 PM
shawnman2001's Avatar
Default 2002 blazer 4x4 wont go into 4hi
I need Help
I have a 2002 blazer ls and i will not go into 4hi. when i push the 4hi button while in park or drive it does nothing. not even blink. If i puch 4hi in neutral, 4hi and 4lo lights blink a few times then it returns to 2hi. If i push 4lo while in neutral it engages and works fine. I dont understand why it will not go into 4hi if it goes into 4lo just fine. anyone have any ideas. The snows getting deep and id like to use 4hi. Thanks
Shawn
Old December 13th, 2006, 11:34 AM
GUS
GUS's Avatar
Default RE: 2002 blazer 4x4 wont go into 4hi
I HAVE A 2003 S-10 AND HAD THE SAME PROBLEM.ON THE PASSENGER SIDE BEHIND THE KICK PANEL THERE IS A TRANSFER CASE CONTROL MODULE .THE CONNECTION ON MINE WERE CORODED I CLEANED THEME AND PUT DIELECTRIC GREASE ON IT NOW WORKS FINE
Old December 16th, 2006, 6:41 AM
kcb37's Avatar
That sound like a good start and hopefully an easy fix. You also have an actuator or something like that on the transefer and the front axle that shifts the transfer and the diff in. If you check the plugs and they are good, (check on the transfer too)check that.
Old January 11th, 2011, 7:56 PM
YAMAHA69's Avatar
Default 98 s10
I HAVE A 98 S10 COULD THAT BE THE SAME PROBLEM WITH MINE IT BLINKS 5 TIMES AND 1OUT OF 10 TIMES goes IN TO 4 HI
Old January 12th, 2011, 7:33 AM
snowbound's Avatar
Default 4hi
I have a 98 S10, had the same problem. Try replacing the switch. It's easy, not too expensive, and tend to wear out from the heat. One way to test is to hold the button, press hard, see if you can at least hear the solenoid click.
Old January 13th, 2011, 11:18 AM
YAMAHA69's Avatar
The one on the dash? If so I did and still nothing I was told it was something called a ecoder motor
Old January 14th, 2011, 3:10 AM
snowbound's Avatar
I think it's either a decoder or encoder. Anyhow, check out this site:http://www.automotivehelper.com/topic346045.htm
dmsreds10
January 28th, 2016 2:02 PM
slovcan
Silverado & Fullsize Pick-ups
October 25th, 2009 10:26 AM
cassandra
December 21st, 2007 8:40 AM
cport
October 14th, 2007 1:35 PM
rickjbr
April 10th, 2007 1:50 PM
Quick Reply: 2002 blazer 4x4 wont go into 4hi
