2003 S10 Fuel Pump
2003 S10 Fuel Pump
My 2003 S-10 (4.3L V6) is not starting. Last time it started it ran fine, I filled the tank drove home and parked it. It sat for a couple weeks without running, and when I went to use it again it did not start. It cranks strong and I could smell gas when I was trying to start it so I decided to replace the plugs and wires. It still did not start, so I sprayed some starting fluid in the throttle body and after cranking a little bit it fired up. I drove it around for 15-20 mins. without any problems. I brought it home and parked it and went out at three different times that night and it fired right up after 1-2 cranks. The next day I tried to use it and it would not start again. Today I went out and got a new fuel filter and a pressure tester, when I turn the key on I hear the fuel pump humming for 2-3 seconds. I replaced the filter and connected up the pressure tester and with the key on engine not running I am getting 52psi on the gauge. Is this enough pressure? I am starting to think ignition module but I saw on the forum that the pressure needs to be at least 55psi so I am second guessing myself now.
Also, when I am trying to start it and it doesn't start, when I let off the key the engine sometimes sputters and bluish smoke comes out of the TB.
Thanks in advance,
Nick
Thanks in advance,
Nick
mangomanj
Express & G-Series Vans
August 17th, 2014 9:51 PM
22charlie
March 21st, 2013 9:54 AM
BRB
Silverado & Fullsize Pick-ups
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
