S-10 & Blazer 1982-2005
95 s10 backfire/ air/fuel???
Old March 20th, 2011, 2:42 PM
snookdawg's Avatar
Default 95 s10 backfire/ air/fuel???
Okay, so this is a 95 s-10 with a 98 rebuilt motor. I'm trying to help my neighbor so i dont know exact details on what all was done. problem started couple weeks after the rebuilt engine was dropped, someone put low grade gas and had been putting medium grade. now it cranks but it put put puts and sputters and has aggresive backfiring. it'll idle alright for a little bit. thinking air/fuel ratio is getting screwed up somewhere. i thought (i do honda etc..) maybe the ecu for that was in the truck needed one to match. ie: 95 body/ecu with 98 motor... needs 98 ecu to match with motor? but i guess thats not a big deal with these. its 2.2 manual. i will put up pics, but frankly dont know what to do. have changed vacuum hoses etc.. theres alot of wires etc they never got plugged back up, but shouldnt be anything of that much importance to the problem?
Old March 23rd, 2011, 3:18 AM
waltd140's Avatar
I would start with some octane boost, then try changing the fuel filter, then plugs & wires, then rip your hair out. You say it went for a few weeks, so the swap motor ran good for a bit before the low grade gas, so it seems the swap took OK. Maybe water in the gas did bad things.
QBert
May 5th, 2021 10:00 PM
justchilln1424
November 7th, 2008 1:42 PM
cbr600rrnut
October 23rd, 2008 1:19 PM
rustedduck
Silverado & Fullsize Pick-ups
October 3rd, 2008 10:45 AM
Rob
Engine Building & Overhauling
January 26th, 2007 10:35 PM
Quick Reply: 95 s10 backfire/ air/fuel???
