2 door chevy blazer over heating??
I have a 94 cheavy blazer that overheats with the plow up. I know the truck will obviously run warmer cause the plow is blocking the air flow. but it never used to do this with the plow on. i have replaced the radiator, t stat,and fan clutch all work fine. but the truck still overheats. i dont seem to be losing coolant. so now wat should i look for??
RE: 2 door chevy blazer over heating??
well im pretty sure the stat is good cause it runs cool when there is no plow on.....and i have been meaning to check thetiming has been running a little slugish.. thanks ill check that and getback to ya
thisnthat
November 20th, 2012 11:36 AM
