S-10 & Blazer 1982-2005
01 what would cause triple fuel consumption
Old July 19th, 2011, 7:49 AM
rhaser's Avatar
Default 01 what would cause triple fuel consumption
When its cold seems to run fine. after 2 minutes or so it starts dumping fuel! it did burn out the plastic t that connects the exhaust to the smog pump. it sounded like i had a major leak. does that mean one of the check valves is bad? would that cause the fuel prob when it warms. i have already thrown plugs wires cap 02 sensor at it. i pulled both forward 02 sensors after running and they are both wet?
Old July 19th, 2011, 5:58 PM
EinST's Avatar
If you have an OBD scanner, check any parameters that change drastically at the 2-minute mark, e.g., sometimes a knock sensor going haywire can cause spark retardation and fuel dumping. Other than that, it's probably best to take it in for service before the catalytic converter is a goner.
Danieljarman
April 29th, 2014 5:32 PM
rhaser
July 17th, 2011 12:39 PM
Clay24
Silverado & Fullsize Pick-ups
January 9th, 2007 3:18 AM
Quick Reply: 01 what would cause triple fuel consumption
