Blazer won't start
Blazer won't start
Went out this morning to start my 2001 blazer and it won't turn over not even a click. Tried jumper cables nothing. Battery connections are good. The volt meter on the dash said it was getting about 11.5 volts without the jumper cables. No we did not leave any lights on last night. We did have 2 really bad storms come through last night and I'm wondering if it got struck by lightning. Pretty far fetched I know.
Check the starter and the starter solenoid as the first step. Also check to see if you are getting voltage at the solenoid when the key is turned to start.
Have you had the problem again? the Same happend to me & it did it again. I let it sit until the next day & it started again. is there a solution to this problem? Pls confirm or direct me the the source to solve the issue. TXs. Mike.
1995 chevy s10 blazer all is working, but when I went to strat it, nothing happened. sat for a day & it started. ran for 3-4 days & it did it again. new battery, alt. charging, new ignition control switch. pls help. can't figure whats wrong. THX MIke
shiner2001
May 12th, 2010 9:59 PM
