Car Shakes when braking, tried everything HELP!
#11
Yes, in winters, when driving on rough frozen surfaces the bead wires inside the tubeless tires would be reshaped, which causes the tires go wobbly (since tire is not a perfect circle any more). This might be a reason for the shakes but I am not sure about it.
#12
Site Ambassador
Since you replaced almost all the steering related wear items, I'd take a close look at your rack & pinion unit. Have a helper work the steering wheel back and forth and/or rock the wheels like you did, while you are under the truck and see if the tie rods at the rack are able to slop in and out.
#13
he said "
Went ahead and replaced Idler Arm, Center Link, Inner & Outer Tie Rods, Sway Bar Links.
he wouldnt have rack and pinion in that kind of setup. I m going to stick with bad tires.
#15
Professional Mechanic
I will repeat this again. Anything that happens while braking is almost alway a brake problem. Just because something was replaced or turned it does not mean it is good. Could be cheap parts, turned incorrectly, turned too thin. Some part of the brakes could be sticking making the rotors or drums get hot. Improper/ un equal torque of the lug nuts can cause it. In my 15 years of working on cars only 1 time did I see it not be a brake problem per say. The truck had been in a front accident, it slide side ways for several feet then may have hit a pot hole or curb. This bent the rear axle hub causing a vibration only felt while braking. If your car/ truck was not wrecked this is not likely. Also worn out suspension parts would vibrate all the time not only while braking. Most of the time worn out parts do not cause a vibration anyways the force of the vehicle in motion will push any front wheel with a bad part out and back and will keep it there until the vehicle stops.
#16
Ive had that problem before too, here is what it was for me. the problem is in the rear brakes. You need to first get a quart of new brake fluid and bleed your brake lines. you need to clean out all that black corrosion out of the system. I guess all that gunk makes one of the brakes stick then it pulses the fluid across to the other rear brake and it seems to cause some kind of oscillation between the two rear brakes. One way to test out if it is your rear brakes is to take your garden hose and shoot alot water up into the rear drums then take it for a quick drive .. if it isn't hanging it wont shake like it dose.. I went thru so much money and opinions finding this out that I damn near scraped my truck because of it.. but do the water test and see for your self what the guy that posted just before me said is right if it happens when you push on the brakes its the brakes
dartlord2001
1988 - 1998 (GMT400)
89
January 1st, 2024 5:30 PM
Goblin1488
Silverado & Fullsize Pick-ups
March 21st, 2013 7:52 PM
VanMan12
Express & G-Series Vans
August 17th, 2012 5:54 PM
toddandtamara
December 25th, 2008 7:07 PM
