S-10 & Blazer 1982-2005
battery draw: RDO BATT fuse is killing my battery
Old April 5th, 2008, 7:54 PM
rwrows's Avatar
Default battery draw: RDO BATT fuse is killing my battery
hey guys. i'm the proud new owner of a 99 s10 blazer and i have an electrical issue. my battery gets drained after a day or two. i've narrowed the source to RDO BATT circuit. when i pull the fuse, i get normal battery draw, but with the fuse in i get excessive battery draw. can anyone help me out?? thanks in advance.
Old April 5th, 2008, 10:50 PM
Banned
shawnvw's Avatar
Default RE: battery draw: RDO BATT fuse is killing my battery
There are only 3 things on that fuse, the radio, instrument panel, and electronic climate control module(if equipped). Put your fuse in, hook up your amp meter and watch the draw. Unplug the radio, watch to see if the draw drops. If it does, you're looking at a radio. If not, do the same for the IPC, and the ECC.
Old April 6th, 2008, 9:52 AM
rwrows's Avatar
awesome. that's what i'll do. how do i know if i have electronic climate control?? i don't think i have it because i just have a **** to turn to blue or red. also, what's the easiest way to unplug the radio? do i have to remove it??
Old April 6th, 2008, 12:04 PM
Banned
shawnvw's Avatar
Your climate ontrols will either be digital, or analog(just regular ***** to adjust), The best way to check the radio, is to accually remove the radio and unplug it
Newsom09
December 29th, 2020 11:46 AM
Burgermeisteradam
April 2nd, 2015 12:14 PM
Ron Malinowski
Silverado & Fullsize Pick-ups
May 29th, 2014 11:03 PM
Matts10
November 5th, 2010 8:19 PM
Quick Reply: battery draw: RDO BATT fuse is killing my battery
