do i need to shim the starter
ok ill start with the last time i replaced my starter i had to use shims in order to keep it from making a high pitched whining sound. since then i just replaced the pilot bushing, flywheel, clutch,pressure plate, and the throwout bearing and hydraulic cylinder. but now when i put the truck back together it sometimes make a bad grinding sound when i start the truck i did leave the same shim i had in there before but with the new starter should i take the shim out or put more in.
77chevy1
Express & G-Series Vans
March 11th, 2010 12:13 AM
freedomfighter_87
December 7th, 2009 7:32 PM
freedomfighter_87
December 3rd, 2009 6:30 PM
