Engine Noise Over Radio
I just bought a 2002 S10 4x4 4.3 with 44,000 miles. Runs great but I get loud engine / electrical noise over the standard radio and my XM radio. Any ideas how I can correct the problem ?
RE: Engine Noise Over Radio
Does the noise come through the speakers when using FM radio as well as XM? or just the XM?
If it is just the XM, you could be picking up a lot of noise when using the accessory outlet.
If it is through fm stations as well as when your using the xm, your problem could be a por radio ground, or a poor ground in the antenna circuit...usualy occurs at the antenna base where it attaches to the body
runningon61
May 4th, 2021 4:24 AM
thisnthat
November 20th, 2012 11:36 AM
adamant
Silverado & Fullsize Pick-ups
February 15th, 2009 8:49 AM
nost1
January 25th, 2007 7:22 AM
