front rearend
RE: front rearend
k whi wanna know is if i weld my front rearend up so when i put it ib 4x4 both tires will dig when i take it out of 4x4 will it be in 2 wheel drive or always locked up hope this explains it better and thank you for your answers
RE: front rearend
I'm assuming you are referring to the "Front Differential".[/align][/align]The differential is designed that way for a reason. If you lock the differential with a mini-spool or god forbid if you weld it, you can overheat the driveline and cause damage to the transfer case. [/align]
RE: front rearend
yes i know it could damage something but i just want to know . when welded both tires will spin in 4x4 take it out of 4x4 will they not be locked up??????
joe200120012001
August 22nd, 2007 7:35 PM
