?? Installing cruise control in 2003 S-10 Pickup
Now what...??
I bought & installed a complete good used steering column (with cruise control/turn signal shaft), steering wheel and all.
I then got a cruise control module with the cable from another 2003 S-10 PU, & I installed it on the drivers side of the firewall, near the top.
To check the electrical plug that already existed under the hood near the module that I had just installed, I turned-on the ignition key.
Then with the ignition key turned-on, I found 2 of the terminals in the plug had power... so I inserted the electrical plug into the module.
I drove the pickup, but the cruise control didn't work.
Does anyone have any ideas as to what I need to do to get it to work?
pcwilcox
October 21st, 2013 11:00 AM
liljoe66
August 5th, 2011 12:44 PM
