lifter,rod or scrap
lifter,rod or scrap
My 1996balzer 4.3 V6 blew the oil cooler line on my wife.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
The stalled with a puddle of oil under it. Towed it home, repaired the line and filled it with oil.<o></o>
It took a little but started after charging the battery, Let run for 30 min no problem. Next day drove it around the block and it started a rapping or knocking noise I have pulled each plug wire the sound does not change. It does get louder and more frequent the higher the RPM.<o></o>
ideas. it has 165K, I changed fuel spider and water pump in Sept.<o></o>
<o></o>
I am looking for was to id the noise<o></o>
<o></o>
williestargell
Express & G-Series Vans
August 14th, 2014 9:48 AM
