Need help s10 cranks but won't start
Okay for the last few weeks my 98 s10 2.2L has been acting up! Every now and then it will crank but not start! And sometimes it will start up with no problem! It has new fuel filter and the fuel pump seems to be fine! If you have any idea what it could be please let me know
When you say it won't start, is that it won't start at all or will it start after extended cranking? Do a fuel pressure check. It could also be the check valve if it starts after extended cranking. When it will not start spray starter fluid into the throttle body. If it runs for a few seconds then it is a fuel problem.
fryerdiesel
June 24th, 2011 1:26 PM
