Oil filter adapter lines 99 blazer - Chevrolet Forum - Chevy Enthusiasts Forums
December 30th, 2008, 7:26 PM   #1
I am replacing the lines that run from the oil filter to the engine block. I got the bolts out but cannot remove the old line. The rear fitting is too large to fit between the engine and the axle. I have seen one recommendation to cut the rubber section of the lines and that would work, but I am worried about getting the new line in there. There has to be a trick to this. Please help!
johndb's Avatar
Junior Member
peterborough ont can
December 31st, 2008, 9:36 AM   #2
RE: Oil filter adapter lines 99 blazer
I don't mean to sound stupid but can you not just lower the axle or raise the engine a bit?
December 31st, 2008, 2:21 PM   #3
Thanks,
We did jack up the engine. Just needed jacked up a hair to get enough clearance so we did not have to unbolt the mount.
Tags
Sponsors
  • Ask a Question
    Get answers from community experts
What's your question?
Send
