P0420 code, o2 sensor replaced, service light is back same code
Hello, I have a 1997 Chevy s10 4.3 vortec (x) 4x4 extended cab. I have a o2 sensor low efficiency code p0420. I replaced with a new o2 sensor and light came back on after resetting, in about 30 miles of drive time. Has anyone had this issue and resolved it? And if so, I would appreciate some feedback on where to go next. I have tried carb cleaner in the carb, and let it soak for a while, no success. I was thinking the cat, but its not losing power. It has 168,000 miles, looks like the cats been on there a while. I put some cleaner in the tank for the injectors etc. And 93 octane gas. No difference. Any help is appreciated, thanks in advance
p0420 and p0430 almost always end up being cats and I wouldn't recommend anything other than OEM, at that mileage I wouldn't be surprised. If you have access to a scantool you may be able to do a test drive watching 02 sensor data
