Intermittent no start
My first time please bear with me. Owner of a Chevy S10 2003 LS 2.2L Vortec. Out of the blue it sometimes starts and other times not. Each time you turn the key lights on the dash dim low. I thought because of the age of the truck It needed new keys. I bought a new Keyway had it pinned by locksmith with two new keys. NO LUCK it continued to start sometimes and not others. I thought of the starter relay. Buying a new one it worked for maybe a day or two and right back at it. I thought maybe the computer. On line bought a computer plugged it it and ran through the rekey process. Again sometimes it would works other times no. So I checked the fuse box. Removed both hot wires or attached wires to the fuse box cleaned them up and it ran great for about 3-4 days and again back at it. I chased the wires from the fuse box and found one wire with bare spot. Tapped it up and all was good for about 2-3 days and again right back at it. I'm at my wits ends Can anyone help PLEASE.
I see you have zero replies. Let me give a you a couple of tips on getting help in a forum ...
#1 - describe your problem in the title. "help" is probably the worst one you could choose. Everyone is here for help.
#2 - Post in the correct section. All the S10 owners are watching the S10 section.
I'll fix your post this time, but keep this in mind when using forums.
Thought that i could be battery so I just bought new one about 2weeks ago. I took the truck to garage and they tell me today that they can not find anything right now as they have had it all day.
Tom Miks
January 27th, 2012 5:23 PM
