S-10 & Blazer 1982-2005
Rough idle, injector flush 98 s-10 Blazer
Old October 29th, 2006, 9:39 AM
ultra7350's Avatar
Default Rough idle, injector flush 98 s-10 Blazer
My blazer has had a rough idle for the past year. I have just replaced the air filter, plug, wires, coil and router. I did a throttle clean also. Good fuel trims, injectors tested OK and no codes with the the tech 2. Still has a rough idle. I have read a service buliton aboutPopit valves sticking when dirty for my type of fuel injection. The next thing I want to do is a injector flush. I know how to do the injector flush but I need to know what to disconnect since it is hard to get to the fuel pump. I pulled the fuel pump relay and the engine still runs. I work with a old GM mechanic and he told me you need to pull the oil sending unit fuse also. Is that correct? If so, where is it?
macmommy
April 22nd, 2020 1:23 PM
Sethyates72
February 1st, 2014 7:53 AM
DCSCO
June 11th, 2013 5:43 PM
JoeBlow
Silverado & Fullsize Pick-ups
11
April 27th, 2012 11:08 AM
Quick Reply: Rough idle, injector flush 98 s-10 Blazer
